I spend 3hrs one day and another 2 fixing a @Stratasys UPrint se. it had a bad head jam and we had to heat the cover until we could get most of the plastic out and remove it. Luckily it now works.
Looks like a switch mechanism for two filaments with one feeder wheel. It seems Two side-blocks have filament paths.Are they act as two heat-blocks? And there should be two nozzles underneath?
Brutal
@Xiaojun_Liu correct. The se uses a bar in the back to switch which filament is actively being driven.
they should have used an Ender 3
@Chevrolet_Diesel_Nat Jo is just trolling. Ender3 doesn’t do heated chamber soluble support ABS prints. Also came out like… 5 years later.
@Ryan_Carlyle ok that’s what I thought. Sorry I am very knowledgeable of other printers besides ones I’ve researched about or ones I’ve worked with
