I seem to be having an issue with either the PSU or the laser
I seem to be having an issue with either the PSU or the laser tube in my K40. When I first got it, 90% power was about 12-14mA. Now, only after about 50 hours use, I am only getting a current draw of 8-10mA. I was always running the tube at about 6-8 mA, unless cutting thicker MDF, where I ran it at about 10-12mA. Never overheated the tube, all connections are tight. Anyone have any ideas as to what is going on. I should mention that I am running an Arduino/Ramps control system.
Where are you located @funinthefalls ?
I am in Niagara Falls, Ontario, Canada. But I have a Niagara Falls, NY address that I can receive from as small as an envelope up to the size of a transport truck trailer. (I use it for my business so I can do my own customs brokering when I order parts or stock from the States.)
tube gaz leak ?
Ok…when I get off today I will give you a shout.
Thanks Scott.
