I saw the article about electroplating ABS… I decided to try Electroplating PLA models.
You can use THF and graphite (solution) to paint the graphite coating onto the PLA then use whatever metal you want to electroplate it. We used copper since it is simple and less nasty chemicals are involved.
The THF is nasty so use a mask or a vent hood to deal with it. at 0.25 amps it took about an hour to get this far. I am going run it a little longer for better coverage.
With Conductive filament starting to be available you do not need to mess with the chemical bath/graphite paint (the THF in this case). You would just directly electroplate the printed object.
