I run TinyG V8 with Chilipper and all of a sudden the footprint (think
I run TinyG V8 with Chilipper and all of a sudden the footprint (think thats what you would call it) of the project is 10 times size of the gcoded project. Ive been scratching my head and I am a newby. If anyone could give me the simple answer that would be grate… Kym
What are you making your gcode with. Also do you think maybe it’s in inches instead of mm
Or perhaps the axis calibration has been lost. Steps per mm.
I am still unsure what to do. I have posted below the coding I have. I use Vetric Aspire 8 and drag project into Chilipper.
If you could let me know whats wrong with my coding that may solve the problem… Thanks again.
{“ej”:""}
{“js”:1}
{“sr”:n}
{“sv”:1}
{“si”:250}
{“qr”:n}
{“qv”:1}
{“ec”:0}
{“jv”:4}
{“hp”:n}
{“fb”:n}
{“mt”:n}
{“sr”:{“line”:t,“posx”:t,“posy”:t,“posz”:t,“vel”:t,“unit”:t,“stat”:t,“feed”:t,“coor”:t,“momo”:t,“plan”:t,“path”:t,“dist”:t,“mpox”:t,“mpoy”:t,“mpoz”:t}}
X position: 0.000 mm
Y position: 0.000 mm
Z position: 0.000 mm
A position: 0.000 deg
Feed rate: 0.000 mm/min
Velocity: 0.000 mm/min
Units: G21 - millimeter mode
Coordinate system: G54 - coordinate system 1
Distance mode: G90 - absolute distance mode
Feed rate mode: G94 - units-per-minute mode (i.e. feedrate mode)
Machine state: Ready
tinyg [mm] ok>
{“ej”:""}
[fb] firmware build 440.18
[fv] firmware version 0.97
[hp] hardware platform 1.00
[hv] hardware version 8.00
[id] TinyG ID 2X2660-FHV
[ja] junction acceleration 100000 mm
[ct] chordal tolerance 0.0100 mm
[sl] soft limit enable 0
[st] switch type 0 [0=NO,1=NC]
[mt] motor idle timeout 2.00 Sec
[ej] enable json mode 0 [0=text,1=JSON]
[jv] json verbosity 4 [0=silent,1=footer,2=messages,3=configs,4=linenum,5=verbose]
[js] json serialize style 1 [0=relaxed,1=strict]
[tv] text verbosity 1 [0=silent,1=verbose]
[qv] queue report verbosity 1 [0=off,1=single,2=triple]
[sv] status report verbosity 1 [0=off,1=filtered,2=verbose]
[si] status interval 250 ms
[ec] expand LF to CRLF on TX 0 [0=off,1=on]
[ee] enable echo 0 [0=off,1=on]
[ex] enable flow control 2 [0=off,1=XON/XOFF, 2=RTS/CTS]
[baud] USB baud rate 5 [1=9600,2=19200,3=38400,4=57600,5=115200,6=230400]
[net] network mode 0 [0=master]
[gpl] default gcode plane 0 [0=G17,1=G18,2=G19]
[gun] default gcode units mode 1 [0=G20,1=G21]
[gco] default gcode coord system 1 [1-6 (G54-G59)]
[gpa] default gcode path control 2 [0=G61,1=G61.1,2=G64]
[gdi] default gcode distance mode 0 [0=G90,1=G91]
[1ma] m1 map to axis 0 [0=X,1=Y,2=Z…]
[1sa] m1 step angle 1.800 deg
[1tr] m1 travel per revolution 1.2500 mm
[1mi] m1 microsteps 8 [1,2,4,8]
[1po] m1 polarity 0 [0=normal,1=reverse]
[1pm] m1 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[2ma] m2 map to axis 1 [0=X,1=Y,2=Z…]
[2sa] m2 step angle 1.800 deg
[2tr] m2 travel per revolution 1.2500 mm
[2mi] m2 microsteps 8 [1,2,4,8]
[2po] m2 polarity 0 [0=normal,1=reverse]
[2pm] m2 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[3ma] m3 map to axis 1 [0=X,1=Y,2=Z…]
[3sa] m3 step angle 1.800 deg
[3tr] m3 travel per revolution 1.2500 mm
[3mi] m3 microsteps 8 [1,2,4,8]
[3po] m3 polarity 1 [0=normal,1=reverse]
[3pm] m3 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[4ma] m4 map to axis 2 [0=X,1=Y,2=Z…]
[4sa] m4 step angle 1.800 deg
[4tr] m4 travel per revolution 1.2500 mm
[4mi] m4 microsteps 8 [1,2,4,8]
[4po] m4 polarity 0 [0=normal,1=reverse]
[4pm] m4 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving]
[xam] x axis mode 1 [standard]
[xvm] x velocity maximum 800 mm/min
[xfr] x feedrate maximum 800 mm/min
[xtn] x travel minimum 0.000 mm
[xtm] x travel maximum 150.000 mm
[xjm] x jerk maximum 20 mm/min^3 * 1 million
[xjh] x jerk homing 40 mm/min^3 * 1 million
[xjd] x junction deviation 0.0500 mm (larger is faster)
[xsn] x switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[xsx] x switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[xsv] x search velocity 500 mm/min
[xlv] x latch velocity 100 mm/min
[xlb] x latch backoff 5.000 mm
[xzb] x zero backoff 1.000 mm
[yam] y axis mode 1 [standard]
[yvm] y velocity maximum 800 mm/min
[yfr] y feedrate maximum 800 mm/min
[ytn] y travel minimum 0.000 mm
[ytm] y travel maximum 150.000 mm
[yjm] y jerk maximum 20 mm/min^3 * 1 million
[yjh] y jerk homing 40 mm/min^3 * 1 million
[yjd] y junction deviation 0.0500 mm (larger is faster)
[ysn] y switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[ysx] y switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[ysv] y search velocity 500 mm/min
[ylv] y latch velocity 100 mm/min
[ylb] y latch backoff 5.000 mm
[yzb] y zero backoff 1.000 mm
[zam] z axis mode 1 [standard]
[zvm] z velocity maximum 800 mm/min
[zfr] z feedrate maximum 800 mm/min
[ztn] z travel minimum 0.000 mm
[ztm] z travel maximum 75.000 mm
[zjm] z jerk maximum 20 mm/min^3 * 1 million
[zjh] z jerk homing 40 mm/min^3 * 1 million
[zjd] z junction deviation 0.0500 mm (larger is faster)
[zsn] z switch min 0 [0=off,1=homing,2=limit,3=limit+homing]
[zsx] z switch max 1 [0=off,1=homing,2=limit,3=limit+homing]
[zsv] z search velocity 400 mm/min
[zlv] z latch velocity 100 mm/min
[zlb] z latch backoff 5.000 mm
[zzb] z zero backoff 1.000 mm
[aam] a axis mode 3 [radius]
[avm] a velocity maximum 230400 deg/min
[afr] a feedrate maximum 230400 deg/min
[atn] a travel minimum -1.000 deg
[atm] a travel maximum -1.000 deg
[ajm] a jerk maximum 5760 deg/min^3 * 1 million
[ajh] a jerk homing 11520 deg/min^3 * 1 million
[ajd] a junction deviation 0.0500 deg (larger is faster)
[ara] a radius value 0.1990 deg
[asn] a switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[asx] a switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[asv] a search velocity 600 deg/min
[alv] a latch velocity 100 deg/min
[alb] a latch backoff 5.000 deg
[azb] a zero backoff 2.000 deg
[bam] b axis mode 0 [disabled]
[bvm] b velocity maximum 3600 deg/min
[bfr] b feedrate maximum 3600 deg/min
[btn] b travel minimum -1.000 deg
[btm] b travel maximum -1.000 deg
[bjm] b jerk maximum 20 deg/min^3 * 1 million
[bjd] b junction deviation 0.0500 deg (larger is faster)
[bra] b radius value 1.0000 deg
[cam] c axis mode 0 [disabled]
[cvm] c velocity maximum 3600 deg/min
[cfr] c feedrate maximum 3600 deg/min
[ctn] c travel minimum -1.000 deg
[ctm] c travel maximum -1.000 deg
[cjm] c jerk maximum 20 deg/min^3 * 1 million
[cjd] c junction deviation 0.0500 deg (larger is faster)
[cra] c radius value 1.0000 deg
[p1frq] pwm frequency 100 Hz
[p1csl] pwm cw speed lo 1000 RPM
[p1csh] pwm cw speed hi 2000 RPM
[p1cpl] pwm cw phase lo 0.125 [0…1]
[p1cph] pwm cw phase hi 0.200 [0…1]
[p1wsl] pwm ccw speed lo 1000 RPM
[p1wsh] pwm ccw speed hi 2000 RPM
[p1wpl] pwm ccw phase lo 0.125 [0…1]
[p1wph] pwm ccw phase hi 0.200 [0…1]
[p1pof] pwm phase off 0.100 [0…1]
[g54x] g54 x offset 0.000 mm
[g54y] g54 y offset 0.000 mm
[g54z] g54 z offset 0.000 mm
[g54a] g54 a offset 0.000 deg
[g54b] g54 b offset 0.000 deg
[g54c] g54 c offset 0.000 deg
[g55x] g55 x offset 75.000 mm
[g55y] g55 y offset 75.000 mm
[g55z] g55 z offset 0.000 mm
[g55a] g55 a offset 0.000 deg
[g55b] g55 b offset 0.000 deg
[g55c] g55 c offset 0.000 deg
[g56x] g56 x offset 0.000 mm
[g56y] g56 y offset 0.000 mm
[g56z] g56 z offset 0.000 mm
[g56a] g56 a offset 0.000 deg
[g56b] g56 b offset 0.000 deg
[g56c] g56 c offset 0.000 deg
[g57x] g57 x offset 0.000 mm
[g57y] g57 y offset 0.000 mm
[g57z] g57 z offset 0.000 mm
[g57a] g57 a offset 0.000 deg
[g57b] g57 b offset 0.000 deg
[g57c] g57 c offset 0.000 deg
[g58x] g58 x offset 0.000 mm
[g58y] g58 y offset 0.000 mm
[g58z] g58 z offset 0.000 mm
[g58a] g58 a offset 0.000 deg
[g58b] g58 b offset 0.000 deg
[g58c] g58 c offset 0.000 deg
[g59x] g59 x offset 0.000 mm
[g59y] g59 y offset 0.000 mm
[g59z] g59 z offset 0.000 mm
[g59a] g59 a offset 0.000 deg
[g59b] g59 b offset 0.000 deg
[g59c] g59 c offset 0.000 deg
[g92x] g92 x offset 0.000 mm
[g92y] g92 y offset 0.000 mm
[g92z] g92 z offset 0.000 mm
[g92a] g92 a offset 0.000 deg
[g92b] g92 b offset 0.000 deg
[g92c] g92 c offset 0.000 deg
[g28x] g28 x position 0.000 mm
[g28y] g28 y position 0.000 mm
[g28z] g28 z position 0.000 mm
[g28a] g28 a position 0.000 deg
[g28b] g28 b position 0.000 deg
[g28c] g28 c position 0.000 deg
[g30x] g30 x position 0.000 mm
[g30y] g30 y position 0.000 mm
[g30z] g30 z position 0.000 mm
[g30a] g30 a position 0.000 deg
[g30b] g30 b position 0.000 deg
[g30c] g30 c position 0.000 deg
tinyg [mm] ok>
What is your machine, belt or ball screw based or other? Check the microstepping setting $1mi/$2mi/$3mi on your driver (jumper setting) and make sure it reflects TinyG setting for each axis. Make sure that step/rev is correctly set to your machine. Measure linear movement once rotating by 1 revolution or more revolutions and divide total linear distance by number of revolutions to get more accurate results. Once you get close, you will tune it easily to a correct final value.
What post-processor are you using in Vecrtic Aspire? There is a post-processor available for TinyG with inches and mm variants. Easy to find once you Google it.
I know over where you can JOG the machine you can also change the JOG settings: 1 / .1 / .01 / .001
I don’t know if this could cause it. I had accidently made mine 1 and plunged the mill into my spoiler.
Interesting enough though, I have a solid reference for Machine zero now.
Corey
It would be possible to add some intelligence into cp to check whether jogs are going to result in large z axis moves and flag them with a confirmation box.
I also saw issues with homing when a part of the homing cycle might be dragging a bit across a workpiece. I thought that should be changed to home x and y and then home z.
If anyone is interested I can see how easy it would be to do this.
