My question is: Since the PWM has increased to 2KHz (to better suit POV users according to the chip manufacturer) is that really going to help anything since the reset time has also been increased? I guess I don’t really understand the difference between the reset times and PWM.
I have to correct myself from my comment in that post. The reset signal is sent AFTER each block of data not each pixel. So the difference isn’t really that huge. You could make POV work with these depending on how fast you refresh them and how many pixels you have. For example… if you have 100 Pixels it takes 3300 microseconds to transmit the full data block with the new pixels. and 3080 with the old. That means you can theoretically render about 300 x 100 pixels per second(but that is a locked loop). Anyway you can see that that refresh rate is SUUUPER high anyway. Even if your down to 100 renders per second you would be fine.
The PWM rate is a diferent beast. Its the rate at which each LED(red, green blue) is flickering when its ON. So if you had a really high frame rate camera recording video of 1 pixel when its on white(as an example), and your frame rate was faster than 2000frames per second, you would be able to see the LEDs flicker.
