I put some of the wet Taulman 316 Nylon in the oven @ ~150/200 F (warm) for about an hour, let it cool slowly, then printed. Layers are much cleaner, looks like a well tuned ABS print - unlike the first attempt (see earlier pictures.) Also had heated bed glass top w/ hairspray at room temperature instead of 130 C (sorry for mixing units), same peel up on corners at about the same point in the print - heat made no difference.
Ordered Garolite (got green, 1/16" thick 12"x12" for ~$8 each.) I’ll hold off another attempt until it arrives. Also planning on ordering polycarbonate. I think my first print will be a bearing to go with 4.5mm SS balls for submerged saltwater use. I’m interested to see how much a print swells compared to other nylon components.
I may also place some pieces in a high pressure chamber at work to see what would happen 3000 meter depth. Might be humorous if nothing else.
