I need the original/updated KISSlicer config files for the Ares. I updated KISSlicer and screwed with a setting, and now its starting sequence is all messed up. It homes twice, heats up, and goes balls to the wall to print. Previously it would heat up, home, auto level, and then print like a boss.
Ty ty, are those the original files or their latest updated ones?
Kk, this’ll at least get me up and running again!
Personally, I find the settings in the manual work slightly better.
Do you run into issues using that .ini ?
IE;
bed_size_x_mm=200
bed_size_y_mm=200
bed_size_z_mm=200
round_bed=0
I thought the ares printable area is
160X160X160 Round.
That’s one of the issues. If your model is smaller than ø160 and you always center your build, not much of a problem but yes, you need to change bed configuration for general application.
