I need some Help running my Shapeoko 2 with Chilipeppr I have used it
I have used it with my other laptops and it connects up fine but now I can not use it on my dedicated desk top I just added to my setup.
Some issue with the serial ports/USB ports are not connecting/talking.
Any help would be Appreciated!
Hi, please show us screenshots so we can better understand the problem.
Please see this post: https://plus.google.com/+RayKholodovsky/posts/U2r2sgrqb54
two serial ports are coming up but it doesn’t seem like they are connecting. I’m just confused because I can plug my laptop in and it works just fine doing the same steps.
Shapeoko usually runs Grbl. In which case you should be in the /grbl workspace.
I have the TinyG
I am very uncoordinated when it comes to G+ so if anyone could just email me at milwaukeecustomkydex@Gmail.com that would be very awesome!
Please try the following link: http://chilipeppr.com/tinyg?v9=true Make sure you are able to connect to the host where the Serial Port JSON Server is running and the Serial port you are connecting to is correct. Try resetting the TinyG and eventually restart the SJPS from Chilipeppr interface.
The yellow mark next to your commands in serial console means, cp try to send this commands but don’t get a ack from your GRBl Controlloler. Please try to reset the controller and connect again, also sometimes it helps you reset your SPJS, push the quadratic red arrows button and wait a second …
