I connected the Makerbase TFT to the PrintrBoard F5. Due to some restrictions I cannot access the PrintrBoard via USB (see [1] and [2]). So I connect over wifi to the Makerbase TFT and get this:
That’s all. Even a “M500” gives no response! But I need to know the actual z offset. Btw I can move the printer and homing works too. I also tried “M503” but the result was the same…
If you can send commands then the issue is something is filtering out responses. Some software filters out all responses. I suspect that the makerbase tft is doing it.
You can always use something like this and control the printer via a computer over usb in place of the lcd on tx/rx until you get your offset configured. Then once done reconnect the mks tft back to tx/rx for normal operation.
