As shown below, I hooked up 120 LED with a separate 5V/2.4A adapter to work with a NODEMCU ESP-12E with a 5V/500mA from my computer. This is is working fine.
However, when I removed 5V/500mA from the setup and connected NODEMCU 5V/GND to draw power from 5V/2.4A, the CPU, jump wires all got heat up and I smelled the burning…
What should I do to safely to provide NODEMCU 5V power with only one 5V/2.4A power adapter?
Be careful you didn’t connect them in reverse, most ICs get hot and draw all the current when connected in reverse. The overheating may damage them too.
Suggested by a friend, I connected the power from a power supply. Strangely, the overheat issue was gone. So, it must be the power adapter! Thanks for you all to look into this for me! What a great community!
