I need some advice to a simple problem I'm having.
I need some advice to a simple problem I’m having. I’m running grbl-lpc on a Cohesion3D mini with the latest laserweb4.
I home the laser, then jog to where I want the work to begin and set zero. All good so far. I run the job and everything works fine, but now if I press goto X/Y zero it goes to the bottom left of the bed, not the original start position. If I dont press the goto button, but just run job, it goes to the bottom left and starts from there.
How do I get the job to run from the same position each time without having to re jog it?
Thanks.
Try removing M2 from settings->gcode->gcode end.
@Todd_Fleming Excellent - That solved the problems - Thanks very much!
