Yesterday I decided to cut a small box for my wife to use in our bathroom for some cosmetics. This is the first time that I have cut plywood for a box. I was using 1/8in Baltic Birch plywood from Ocooch Hardwoods. Using the stock mirrors and lens, I set my distance from lens to material top to approximately (using a jig) 49.3mm. My mirrors were cleaned and I thought my alignment was good. But, it might not be after all. I also think that I need to work on settings. I tried to cut the plywood at 4mA (20% on my machine) at 15mm/sec with good air assist. Any slower and it really scorched. Any less power and it doesn’t really do much cutting. I ended up having to do enough passes that I got distracted and lost count of how many it took…
Issue: the cut is not at 90º from the surface. There is a slight bevel. I noticed this in particular in areas where a hole was cut for wood fingers to fit into. I used a chisel to square up the fingers and a rasp to square up the holes. I tried to take a photo but the angle is so small I cannot catch it with my camera. My initial guess was focal distance is wrong but I measured it from lens to material. Perhaps I should measure with a ruler and not my jig.
Any ideas?
