I love open hardware initiatives like Open Builds and Inventables. I was able to get the plate design and add nema 17 compatibility from inventables into the ox plates. Then I trim the plate to fit a smaller extrusion.
Now I am working on adding tinyg mounting support for the back plate of my y axis. Without these open plans, it would have taken me more time to get to where I am. Thank you everyone in these great communities.
Yes I did laser cut these acrylics on my own. Having access to a 100w laser cutter sure is useful for prototyping. So far the plates feel very solid. I haven’t put on the z axis yet so I don’t know.
I’m curious about the laser you are going to use. A laser cutter is very high on my list of wants. I’ve been trying to find a fiber laser supplier, but I think I’m going to have to go with C02. Maybe I’m just not looking in the right places. What kind of laser are you going with for your build?
@Mat_Helm got it locally at a store called Regal plastic. $1 a lbs of scrap. @Jamie_Wilburn , I am going with 9mm 445nm diode. Very low power comparing to co2. @Bruce_Lunde thank you. The maker space I joined does help me a lot to get things moving. I think makerspaces are wonderful.
