I know it's all about trial and error with the machines but think to
I know it’s all about trial and error with the machines but think to practise with the cardboard and wood the machine come in, any tips on settings when it comes to cutting the cardboard ?
Start with an easy set of numbers to remember, example 6mA power 10mms speed and go from there
Thanks is it true that the stock laser won’t cut plywood wood wbp, I read it on website that gave u all the settings for the stock machine ?
@Rob_Turner ​ not sure I understood the question. wbp? What’s that? You can cut 3 or 6mm plywood. 3mm should be easy at 10mA power and 10mms speed one pass. Thicker will requiere multiple passes
