I just spent 1:13:55 watching the 2014 hangout when @jlauer and Todd Flaming did a walkthrough of Jscut and Chillipeppr integration. Whats funny is that John ask about how to get everything in the positive Y but that explanation never came. Todd did explain to add a bigger positive number to the Y offset but it just not working for me.
John im sure you have the answer by now, please share
I don’t recall any of that. I have found decent success with JSCut, but I have also found that sometimes it generates inordinately large Gcode files for me. I have been using the SVG Import inside ChiliPeppr lately. It does depend on what your needs are as JScut is pretty full-featured.
@jlauer direct svg on Chilli only seems available on tinyG, nevertheless what are you using it for? Am able to import but don’t see a way to add depth
I’m using it for laser cutting paths, so I don’t need much modification to the path. If you switch to “Mill” in the Gcode tab you will get a Depth of Cut field. You could generate the Gcode in the TinyG workspace and then just switch over to the grbl workspace and it should just auto-load cuz it was the last file.
