I just received my Bltouch and everything connected. G28 command work just fine. I use the g28 command to configure my offsite which was -0.53.
But not everything is flowers, when i run the G29 command(After the g28), it does the first point ok (at xy=0) then it jumps to y=0 and x=10 and goes for the second point where the Pin does not goes down and it crashes the nozzle on the bed and keep forcing it until I turn the power off.
Everything works, M851 commands and g28, but the G29 with 9 points does not work at all.
Ramps 1.4 with Marlin 1.1.0 RC6
