I just noticed that the position of my A-axis isn't being reported in the
I just noticed that the position of my A-axis isn’t being reported in the GUI even though I have selected “Show A-axis”. If I go to the serial console and type “$posa” it does give me the current position. Is there a setting I’m missing here? I thought it had always been working but I rarely had the A-axis visible in the GUI so I don’t know. Any ideas?
Nevermind. I fixed it. I had to issue $posa:true on startup and it worked fine. [update: no, actually I had to redo the startup script for the tinyg as “{“sr”:{“line”:t,“posx”:t,“posy”:t,“posz”:t,“posa”:t,“vel”:t,“unit”:t,“stat”:t,“feed”:t,“coor”:t,“momo”:t,“plan”:t,“path”:t,“dist”:t,“mpox”:t,“mpoy”:t,“mpoz”:t}}” because merely sending “$posa:true” didn’t always work]
I am having the same problem. How do I modify the tinyG startup script to include A-axis reporting (using tinyG firmware 440.20 and jsonserver version 1.94 running on a Rpi3). Thanks!
