I just got FastLED working on a homebrew board using attiny167.
fastled-support
gplus
(Shlomo Zippel) #1
I just got FastLED working on a homebrew board using attiny167. There were a few problems:
  1. I got compile errors (undefined reference to ‘timer0_millis’) which I “solved” with NO_CORRECTION 1
  2. The pin definitions for attiny167 didn’t match the Digispark Pro pinout. Not sure what they are based on but I had to change them since I use the digispark pro stack (micronucleus bootloader and digispark libraries in arduino IDE).
@Daniel_Garcia @Mark_Kriegsman Is this a good way to communicate things like this? Do you prefer github issues / PRs?
(Daniel Garcia) #2
Github issues for things like this, thanks!
(Daniel Garcia) #3
As for the pin definitions, it’s a simple linear port mapping - pins 0-7 on port A are pins 0-7 and pins 0-7 on port B are pins 8-15.
