I have previously used Inkscape with svg files and that has been working great
I have previously used Inkscape with svg files and that has been working great in LaserWeb
I would like to use fusion360 which can export dxf format
Just want to confirm that can work?
Is there anything special to watch out for or tricks to using fusion360 upstream of LaserWeb?
Haven’t use it myself but look for construction lines to be exported as well, as far as i know this cannot be turned off so you will have to delete them.
@Kevin_Lease Are there features in Fusion 360 you prefer over Inkscape (open sourced)? Have you worked with “gcode tools” in Inkscape? Are you using a router or laser?
Laser
I want to make offset cuts around text outlines
Cut plexiglass and place in cut plywood
Versus 3d print both pieces
Wanted to have one design and have flexibility to do it either way
In Inkscape sizes of objects seem to change slightly while I am working on a project took
