I have just recived a MKS SMINI so I can test mine J tech
I have just recived a MKS SMINI so I can test mine J tech laser. But im a little confused. Where is the firmware im going to use? Im using Marlin on ramps 1.4 alot, but this smoothiestuff is brand new for me. Im feeling like a noob, and think I need a noobguide :smiley:
Thank you. I’m not a fan myself. Just need something cheap for now. Going to buy the real smoothie board later.
Hi. I use a mks sbase in cnc Machine. It is not like you but…
The firmware is Download from github mks sbase.
Put the file .Bin in the sd card and power the mks card. The .Bin file Will Be convertirá in other file. Your firmware is ready to use. Now you only need the http://config.txt file to adap your Machine to your mks board.
Save a copy of the http://config.txt file in your pc.
In the instructables web you can find more info about instaling and config the board.
Cheers.
oh i’m sure they will get around to stealing it pretty soon :wink:
