I have issue with marlin 1.0.2 auto-leveling.
I level out the bed that when after command G28 I move hotend around it stays flat, however the measurements of inductive sensor on G29 are not level and that shifts my printing plane.
My printer build plate is steel and I got 4mm inductive sensor.
plate size 300x300mm with 9 points of measurement (extended from 4 because it was same issue)
Here is output of sensor readout from G29 command:
Bed x: 50.00 y: 50.00 z: 4.20
Bed x: 150.00 y: 50.00 z: 4.36
Bed x: 250.00 y: 50.00 z: 4.42
Bed x: 250.00 y: 150.00 z: 3.72
Bed x: 150.00 y: 150.00 z: 3.28
Bed x: 50.00 y: 150.00 z: 3.29
Bed x: 50.00 y: 250.00 z: 2.36
Bed x: 150.00 y: 250.00 z: 2.36
Bed x: 250.00 y: 250.00 z: 2.64
Eqn coefficients: a: 0.00 b: -0.01 d: 4.58
planeNormal x: -0.00 y: 0.01 z: 1.00
echo:endstops hit: Z:2.64
You can notice that measurements on Y=250 are over 1mm away.
Question:
I use some magnets to hold the steep plate bed, does that affect sensor readout? I moved most magnets away up to 50mm from sensor stops, to minimalize that effect (if any).
Does anyone had similar issue?
What does your start code look like? You could be clearing out your leveling before printing.
Generated g-code is never hit, I run manually commands G28 and G29. Then I move around the bed with G1 commands
I found out that the normal calculated is reversed and when I have bed tilted in either X axis or Y axis, after running G29 command, moving hotend moved Z opposite to what it should to keep same Z level above the bed.
Does anyone had that issue? My printer is CoreXY (Smartcore).
here is part of Configration.h for its motor and directions setup:
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it’s not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z true
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false // If true, axis won’t move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won’t move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 300
#define X_MIN_POS 0
#define Y_MAX_POS 300
#define Y_MIN_POS -13
#define Z_MAX_POS 250
#define Z_MIN_POS 0
I did change INVERT_X_DIR and INVERT_Y_DIR and rotated motor connectors with same effect - plane calculated is opposite to plane of bed.
Maybe it is something to do with reversed Z because top bottom is increasing… will do some additional checks
setting INVERT_Z_DIR to false and adjusting motors did nothing, now as I think of it shouldn’t - but I think keeping INVERT_Z_DIR and true and take that into calculation of normal for plane might fix the issue.
small hack into 3-point equation method in Marlin fixed the issue:
added negative readouts for z probe @Marlin_main.cpp line 1024-1026
vector_3 pt1 = vector_3(ABL_PROBE_PT_1_X, ABL_PROBE_PT_1_Y, -z_at_pt_1);
vector_3 pt2 = vector_3(ABL_PROBE_PT_2_X, ABL_PROBE_PT_2_Y, -z_at_pt_2);
vector_3 pt3 = vector_3(ABL_PROBE_PT_3_X, ABL_PROBE_PT_3_Y, -z_at_pt_3);
