I have enough extrusion for a 500mm cube, I have 10mm, 8mm smooth rods,
I have enough extrusion for a 500mm cube, I have 10mm, 8mm smooth rods, I have 10mm trapezoid screws etc, I think it’s time I start building.
Do you all use the same set of stl files or are all machines individual?
Most of the printed parts stay the same, even if you alter the extrusion length or overall dimensions, you just need to also alter the smooth rod lengths to match.
I’ve all rods already…
Not been on the group for a bit, what’s a ’ HercuLien’?
Also, are the printed part stl’s available from one source?
And
Thanks Jim
I’ve started to print the parts, the bearing holders A x4 and B x4… Are these the same? I cannot see a difference once printed
