I have an issue I need a bit of help with. I finally said good buy to my k4O and upgraded to the k50 big blue laser. I have some laser draw files that I want to use on my new machine. Laser draw only lets me export bitmap images and I can not get them to cut in rd works. Any ideas?
The best i have been able to come up with is to load the bitmaps into Inkscape and then use the trace bitmap tool, then save the file as a .DXF file in Inkscape which should then allow you to import it into RDWorks. Sometimes i have issues with it deciding to skip little bits of the file i have converted though, and sometimes it works flawless, but i have not found out whats the trigger for it failing yet. Most of the time i just create the file again from scratch where possible.
@1981therealfury I actually figured it out. Rd works has an outline bitmap function. I just import the bitmap it’s already the right size. Then choose it map handle then outline bitmap. It works great and very easy
Ahh ok, thanks for the heads up, ill look into that
