I have an Azteeg X5 running on my delta, and just recently my cooling fan won’t shut off. Normally, when I power it up the cooling fan’s off with no issues, and it stays off as it should until the second layer of the print. Now it’s on constantly. I haven’t changed anything in the config with relation to the fan setting. M107 won’t stop it - it’s just alwys on.
# Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.4 #
These settings have been the same since I had originally set this up. I’ve even compared it to some archived config files I’ve saved and they’re the same. But now my fan won’t turn off??? Any suggestions?
