I have a troxy x5sa need help
Hi I have a troxy x5sa it has been jammed by a print I had running .
Now the both motors are not working when powerd on they are very had to turn but when I power it off I can move them.
I have opened the power unit thinking it might be a fuse but I can’t see any in there.
Would this be the motors or the main board.
Or if anyone has any ideas that would be great it was working fine before the jam up.
Barry
The reason the motors are hard to move when powered up is because they are powered and holding position and when you remove power(power off) they move because they are no longer being powered.
Look to see if the end stops and end stop wiring is still functional.
Hi yes everything is still working just the motors don’t move.
Everything was working fine untill the jam up with the print.
Barry
Barry, can you show us how you tested the end stop switches?
Hi not sure what you mean with the end stop switches there is a switch on the print head that when pressed you can hear a blip from the main board if that helps.
Also when powerd on all motors are stiff and not free to turn i understand this is normal.
Send it to print and you get the table and the print head get hot and up to temperature but nothing else happens it would normally go straight into print mode.
But nothing happens it just sits there.
Barry
Up date i have found a reset switch and I have movement i all four motors but when I power it on the bed will not stop coming up I have to power off or it will smash everything up as it is i have 2 nozzle marks on the bed.
I’m sure when I normally use it there is a red light that comes on to tell it to stop but unsure hopping someone will help me out that has more knowledge of what’s wrong.
Barry
I’ve just ordered a new sensor there very cheap so I’ll give it ago.
End stop switches are switches at the end of the motion/motor travel to stop the motion by signalling the controller that the end of travel has been reached. Surely you’ve figured this out by googling “what is a endstop switch on a 3D printer”. Right?
Also google “what does the homing mechanism do on a 3D printer”.
If an end stop switch has failed or a wire has been broken then the controller can think that a switch has been triggered when it starts the homing process and so motors are all stopped. Normally the controller will move an axis to trigger a switch and then back off of the switch so it’s no longer triggered. But if somehting is broken/failed, that signal of an end position being reached is continually sent/sensed by the controller and no motion can happen.
Knowing how your machine works means you will better understand why it works, why it doesn’t work and how it can do more. WAY better than just learning what things to click on to make it go. IMO
Hi yes I’ve tested both switches and both work find.
Ot now looks to me that the plate sensor has gone down it used the light up red when it detected the plate rising but no longer does I’ve taken the sensor out and with a multimeter it’s showing short so for under £8 for a new one its worth the chance.
As it stands the plate just keeps risings so I have to shut it down very quickly.
Barry
There should be 3 end stops. X, Y and Z
Cheers I’ll take another look i found one switch on the printer head and another on right hand top up right and also the plate sensor so there must be another that I’ve over looked.
Only two switches and one sensor.
If that “plate sensor” is really a bed leveling sensor then keep looking for the 3rd end stop. Hard to believe it has only X and Y endstops and no Z end stop at the top but could be possible.
Hi I’ve looked everywhere for it but it’s not there is built it myself about 5 years ago and I’ve attached a picture of the lay out.
I think mine had a Z stop near the Y stop, but I don’t think Tronxy were consistent; I think they just made changes so easy to believe that yours used a switch on the print head instead. They also didn’t follow the license for the Marlin firmware and I had to go through the seller to get it to be able to update it.
I ended up so unhappy with mine that I basically redesigned it from the frame out to make it into a working printer, so no experience I had with it years ago is useful for helping diagnose it, and by now my memory is very foggy.
This is a short video of whats happing its almost like tge timing is out.
This is after i fitted a new build plate sensor.
It’s not moving to the correct place to sense the height. You have a problem with moving to the correct X/Y coordinates. Look at X/Y limit switches (likely one is stuck closed).
It is NOT moving smoothly in the X direction in the video! at around 13 seconds you can see it jumping as it moves a little bit to the right. Why even try anything else when it’s not even moving in X/Y correctly? I find it difficult to believe you had this machine working since you would know it does not jump and skip around when it’s moving. That motion is wrong and you need to get it to move smoothly. It seems really odd that a hotend jam broke a bunch of end stops… This machine needs to be treated like it’s brand new DIY and brought up in a step by step manner IMO.
There are dozens of HowTo on how to setup a 3D printer from scratch. Overview:
Move the print head to the center and lower the Z axis manually.
Test each of the limit switches to see them trigger when you use your fingers to trigger them. If you have to move the print head to trigger then depower the board, unplug the motors, repower the board and manually move the print head to trigger the switches and look.
Do the same for the Z axis. You have to google how limit switch testing is done on your controller firmware.
Next you test the X and Y movement is calibrated, ie command it to move 20mm and it moves 20mm. Do this again, starting with the head in the middle and if it wants to home first your manually trigger the switches. if you can’t then you get ready to stop things if it moves the wrong direction or hits the switches and grinds the belts.
Next is testing and setting up the homing operation, G28 IIRC but you can also use the GUI to home X axis and then Y axis. There should be a step-off distance set so once it triggers the switch it’ll back off a few mm. Might be called soft end-stop.
If both X and Y work smoothly and home then test the Z motion.
If you grind gears and belts instead of the motor just skipping steps then you’ll end up probably needing to replace the belt. And letting your hot end smash into your bed and the clip you have on the bed is likely going to break something.
