I had a problem while I was doing a milling using ChiliPeppr.
I had a problem while I was doing a milling using ChiliPeppr. Everything was ok when the electricity went out.
Now I need to know how to restart it in the position I was when this happened. Does anybody know? Thanks.
You mouse over a line of gcode and say “Set as Start Position” so you’ll have to guess where you were at. You can use Inspect Mode in the 3D viewer to mouse around on a line and see what line number it is. Then click the “Jump to Line” button in the mouseover dialog and then “Set as Start Position.” Keep in mind though that starting in the middle of a gcode file can be dangerous if the beginning of the file isn’t run where it sets up mm vs inch, relative vs absolute, work planes, etc.
Thank you. I will try it.
