I hacked at the USB hub a bit and removed the led no one will see from the pcb, and put some of the leads I cut off the printer on it. I’ve got a blue led, and housing so I will just solder some pins on it. Then I got my extension cables in so I did the second AV input for the monitor, HDMI and ethernet for the Pi.
Also worth noting ABS takes spraypaint extremely well. So if you want black it is probably easier to print a lighter color and spray paint it black. Black is a bit harder to get to print nice.
