I found some of my print failures were related to the hot end hanging up on the print…which was wierd as the print looked pretty flat (no overextrusion). Closer examination showed that the extruder had some play in the mount. One screw wouldn’t tighten up because the nut was spinning in place, and honestly, I probably drilled the holes a little wonky.
I disassembled, and used some toothpick pieces to keep the nuts from spinning, I then also wrapped a small rubberband in the groove for the J-head mount. Upon reassembly, the nuts didn’t spin, and the rubber gave the screws a good surface to bite into. Id’ also imagine there’s a little flexibility in the rubber, allowing it to move if something catastrophic happens.
