I finally set my printer up for auto bed leveling but now I’m having a problem with it quitting about 10 percent into the print. I’m using Repetier host and haven’t had this problem before. The only other thing I did was I had to upgrade the firmware to the latest version of marlin as the version I had did not have auto bed leveling. Has anyone else had this issue or possibly know why I’m having this issue… Any help would be greatly appreciated.
I have had such an issue. The polyfuses were triggering and causing everything to stop or stutter. Make sure your fuses are not touching each other and that you have proper cooling. You might want to see if it only happens when the heather is on.
