I don’t know what happened four hours in and it just ed stopped and then it would move slightly then stop. After that my computer crashed. Any help? I’m using repetier.
I can’t help…just know that I have failed this model at LEAST a dozen times.
Maybe the board overheated. This happened once on my pb v1. I cut a hole and placed a fan blowing across the board and y motor. Never happened again.
Fill that skull with candy and you got yourself a brain.
I know this won’t help but… I think it looks kind of cool.
When my board (specifically the poly fuses) overheats, the motors start moving slowly. It is more a sticky start stop movement. I think it does this because the fuses are rapidly cutting in and out. I typically saw the platform heat drop beforehand as well. A fan helped but at some point was not enough, ended up replacing the larger fuse. Hope this helps!
