I am up and running with LW4 - If I use gcode generated from inkscape from an svg it looks good. If I take that same svg and generate the gcode in LW4 i get connecting lines between the objects. I am sure it is a setting but have yet to find it. The laser stays on after the image is burned even when returning to home position.
I also cannot figure out the raster feature. I have tried a few sample images and all I seem to get is burned lines. I have verified that PWM is working but I cannot figure out how to use LW4 to control it. For example I can lower the power settings in LW and it does lower the power of the laser, but past that I am lost.
I have looked for tutorials but have not found anything …yet. I am hoping someone here can point me towards one.
Thanks!
