I am unable to probe using TinyG 442.04 with less than 18mm/sec feedrate.
I am unable to probe using TinyG 442.04 with less than 18mm/sec feedrate. That is too much for PCB probing, as I am using quite expensive bit.
I have recorded 2 probing cycles starting with F20, then F19, F18 and F17 resulting in machine freeze, then RESET and another cycle.
You can see the stepper motors LEDs blinking for G38.2 Z-20 F20 (and F19, F18) when machine works, as expected, and just a single short red LED blink after issuing G38.2 Z-20 F17.
Does anyone face similar issue? Can it be the board malfunctioning?
You will find the video here: https://www.youtube.com/watch?v=R6uxGo4S_Yo
EDIT: Video link updated -> I have recorded another video, as the previous one got Chilipeppr black screen in YouTube.
That’s a TinyG problem. Ask Synthetos. It seems to just not work at that slow of a feed rate.
