Warning: Board breadboard:avr:atmega328bb doesn’t define a ‘build.board’ preference. Auto-set to: AVR_ATMEGA328BB
WARNING: Spurious .github folder in ‘Adafruit DotStar’ library
In file included from /Users/fed/Documents/Arduino/LED_strip_45/LED_strip_45.ino:30:0:
/Users/fed/Documents/Arduino/libraries/FastLED-3.1.6/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.006
pragma message “FastLED version 3.001.006”
In file included from /Users/fed/Library/Arduino15/packages/arduino/hardware/avr/1.6.19/cores/arduino/Arduino.h:28:0,
from sketch/LED_strip_45.ino.cpp:1:
/Users/fed/Documents/Arduino/LED_strip_45/LED_strip_45.ino: In function ‘void fire()’:
/Users/fed/Documents/Arduino/libraries/FastLED-3.1.6/fastled_progmem.h:33:35: error: ‘heatmap_gp’ has both ‘extern’ and initializer #define FL_PROGMEM PROGMEM
/Users/fed/Documents/Arduino/libraries/FastLED-3.1.6/colorutils.h:1672:52: note: in expansion of macro ‘FL_PROGMEM’
extern const TProgmemRGBGradientPalette_byte X[] FL_PROGMEM =
/Users/fed/Documents/Arduino/LED_strip_45/LED_strip_45.ino:455:3: note: in expansion of macro ‘DEFINE_GRADIENT_PALETTE’
DEFINE_GRADIENT_PALETTE( heatmap_gp ) {
LED_strip_45:461: error: ‘heatmap_gp’ was not declared in this scope
CRGBPalette16 myPal = heatmap_gp;
exit status 1
I just tried it. Similar issue. Thanks anyhow. Any further suggestions?
In file included from /Users/fed/Documents/Arduino/LED_strip_47/LED_strip_47.ino:30:0:
/Users/fed/Documents/Arduino/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.006
from sketch/LED_strip_47.ino.cpp:1:
/Users/fed/Documents/Arduino/LED_strip_47/LED_strip_47.ino: In function ‘void fire()’:
/Users/fed/Documents/Arduino/libraries/FastLED/fastled_progmem.h:33:35: error: ‘heatmap_gp’ has both ‘extern’ and initializer #define FL_PROGMEM PROGMEM
/Users/fed/Documents/Arduino/libraries/FastLED/colorutils.h:1672:52: note: in expansion of macro ‘FL_PROGMEM’
/Users/fed/Documents/Arduino/LED_strip_47/LED_strip_47.ino:456:3: note: in expansion of macro ‘DEFINE_GRADIENT_PALETTE’
LED_strip_47:462: error: ‘heatmap_gp’ was not declared in this scope
exit status 1
I believe that’s there to allow you time to upload new code if you’ve done something silly in your program (such as putting your board into such a low power state/sleep mode that it disables USB, not allowing you to upload new code…). There might be other reasons to have it there too.
@Fed_Sanchez , I remembered another reason I often have a delay in my startup. If you do this (without any delay):
void setup() {
Serial.begin(115200); //start serial monitor
//…other setup stuff here…
Serial.print(“Setup complete”); //won’t show up
You might not ever see the Serial.print message because even though Serial.begin has been started, the program gets to the print statement so quickly that the serial monitor hasn’t had a chance to actually connect. If you put about a 1500ms delay after Serial.begin it will allow enough time for the serial monitor to start and the print statement will show up. (The length of the delay needed might depend on the speed of the micro controller being used.) Something like this:
void setup() {
delay(1500);
Serial.print(“Setup complete”); //will show up
