I am starting to get over the hurdle of learning the CoffeeScript syntax and @CoffeeSCad grows more and more awesome as I work in it. Sure, there are some needed features missing still but it is easy to wait for them when it is as powerful as it is already. Loving the object oriented approach and real run-time variables!
I should clarify that the syntax isn’t hard, just different to the languages I usually work in.
Yeah, I also found the syntax rather odd. The syntax of modern languages looks the way it does for good reasons. After you get used to the kind of thinking that programming demands, I find that coffeeScript kind of syntax becomes un-intuitive.
