I am running a mendelmax 3 with dual extruder, are presets for Rambo based printers running marlin and dual extruder support going to be added in future?
Hi Joshua, I’m currently working on adding dual extruder support to the App. In the meantime you can use the custom macros to switch between extruders (T0, T1). Which presets are needed for your printer ?
I may have used the wrong terminology when I said preset, I was just referring to the compatible printer list you can select from in the printer tab in settings, I’ll definitely make use of the macros in the meantime. Thanks.
