I am looking to do some upgrades for the basic K40 laser I just bought. I intend to do bottles and tumblers engraving.
Shortly what I have in mind, but please advise me!!!:
I have a M2 Nano mainboard. Is this enough or should I go for a better kit?
Software, I intend to use K40 Whisperer from Scorch? is this alright for all the setting required to work with a rotary?
3.I found an mini 2 axis rotary, 20cm x 10cm x 20cm that should fit in the laser case , but I am not 100% sure it will work with my board.
Should I go for a adjustable table or a Honeycomb bed?
What else I need for what i intend to do? any other upgrades?
Thank you! I attached some img with my laser, no spam.
I would suggest upgrading the controller to a C3D mini, which is a drop in replacement. Then I would use LightBurn software, it works so much better than anything else, and has a specific module to do rotary engravings. I would also upgrade to an air assist head with a better quality 18mm lens. The Cohesion 3D web site sells all the things you would need to upgrade, they even sell the LightBurn software. Check it out at http://Cohesion3D.com
Your main difficulties would be the focus distance. make yourself a piece of wood to place between your lens and object. and lift the rotary accordingly. otherwise honeycomb bed is the must to reduce fume marks on flat material.
also you could have a look at open source Visicut software (compatible with Smoothieboard like (C3D)), rotary attachment functions.
Thank you for all your answers and advices.
Also,
Is it necessary to upgrade with an air assist head and better quality 18mm lenses if i intend to engrave on stainless steel bottles?
Air assist and better lenses improve the quality of your output but you CAN get it done with stock lenses and no air assist.
Adding these changes is really a matter of enhancing the output quality to meet your needs.
I suggest getting your machine working and set up with a new controller and stock optical parts and then systematically upgrading as you see the need to improve quality. This includes the safety add-ons. This machine can blind you!
