I am having a very strange issue with my Printrbot Simple Pro with heated bed. When using t he cloud slicer, the heatbed is not an option. But as soon as I start printing, the heatbed is turning on and running at its maximum. @Brook_Drumm1 do you have any idea what the heck is going on? I got lucky and noticed it before a fire started the first time, but the bed was so hot that the PEI surface became unstuck and the glue liquified. Any help or ideas form any one would be greatly appreciated.
I was thinking it was related to a Mosfet. I have already disconnected the heated bed, I rarely use it on the Printrbot. I do have heated beds on my 3 Di3’s and 2 Tronxy X1’s so it is not a big deal.
The MOSFET likely failed like mentioned above and shorted to + 12V, in other words it became a stuck on switch. Not possible to fix in software (think of it becoming like a piece of wire). That’s one reason why you never leave your 3D printer unattended (web search 3D printer on fire) and never ever go to bed while printing.
Failed MOSFETs have been reported for years, including on Printrboards (no more likely than any similar controller) on the unofficial http://printrbottalk.com. Pretty easy to replace a through hole version if you can solder. Printrboards have the extruder and bed MOSFETs close enough they can short together with rough handling, fixed by physically separating them (any parent if multiple kids knows this one)
