I am controlling 40 w co 2 laser with audino
From yesterday it will stop if you set the laser output above 40%
Who else knows the cause?
Almost always it stops at this level
Raster processing is possible (only use within 40% of output) Laser output 20% (little output) or machining start can be activated with laser power turned off.
I would appreciate if someone who understands
I am sorry if I do not understand the meaning because I am trying Google translation
https://drive.google.com/file/d/1SO3dETzT_d7AqZ8cQQAIN5nV5YsESmR1/view?usp=drive_web
