You should create a pull request on github so I can take in your changes and publish them to the main widget. I presume you created a fork of the eagle widget on github so you could do your own edits. Iβd love to add this so would welcome a pull request.
@jlauer β Thx John, appreciate your light speed answer
I just powered off The PC for today, so I will pull changes tomorrow.
I thought creating pull request is the way to go, but didnβt want to mess up things.
Yeah, just hit pull request and follow the next few prompts to submit it. Change βMade some changes in Cloud9β to an accurate description of the feature, and you should be all set.
