I a looking for an example of CRGB array. How would I define a new array called newArray of an existing array of leds starting at position 6 and length 10?
I saw come comments on-line but I don’t recall any examples.
Are you asking about CRGBSet or something different? Can you provide more info about what you’re trying to setup?
CRGBSet info:
Simple example:
Maybe this example code will help:
Nice example thanks. More elegant than my way.
Will this work?? Objective is to have an array (without indexing) . In this example, I can change attributes of “beginning” array without have use the index .
CRGBArray<NUM_LEDS> leds;
CRGB beginning [10];
CRGB middle [10];
CRGB end [10];
beginning = leds(1,10);
middle = leds(11,20);
end = leds(21,30);
beginning = CRGB::Black;
middle = CRGB::Red;
end = CRGB:: Black;
CRGBset beginning(leds(1,10)); //set custom ranges
CRGBset middle(leds(11,20));
CRGBset end(leds(21,30));
CRGB colorBeginning(0,0,0); //give names to colors
CRGB colorMiddle(255,0,0);
CRGB colorEnd = CRGB::Black;
Then in the main loop you can do something like:
beginning = colorBeginning;
middle = colorMiddle;
end = colorEnd;
FastLED.show();
thank you Marc. This is exactly the code I was looking for.
OK, one more question. I have a long string the has six of beginning, middle and ends. so two questions
I get a little confused since CRGB isn’t a true array but a pointer back to the original array. So I need “an array of a pointer array of the original Leds array”.
// how do I define CRBGArray as an array?
CRGBArray<NUM_LEDS> leds; //??
// is this the method for indexing a single element of CRGBArray
CRGBset beginning1; //set custom ranges
CRGBset middle1;
CRGBset end1;
beginning[1] = colorBeginning;
middle[1] = colorMiddle;
end[1] = colorEnd;
FastLED.show();
Hi
could you please help me to solve this problem?
when I run this program with //CRGBArray<NUM_LEDS>leds; it just run one time,
While there is an archive of old Google+ FastLED content on Maker Forums, the FastLED community has requested that new conversation happen on Reddit:
