http://nemesisrobotics.com/326-2/
Found an easy hack to change Splines to actual usable polylines in LaserWeb!
So I wrote up a quick tutorial on it. Let me know how it works for you guys.
Bezier curves are preferred by laserweb
For future reference
+Peter van der Walt When I create anything with Vectric software its exported as Dxf anything with an arc in it requires me to convert to a bezier curve or they populate into LW as straight lines
Circles populate as squares…
That’s weird Alex I’ll have to try that from vectric. It’s never given me an issue. I usually import a dxf (with polylines) and export the dxf again when I’m using vectric to edit a drawing.
I usually just use its text tools or the bitmap trace. I’ve never had an issue with its polylines though.
