HPC Laser 1290 – Wavy/Jagged Cuts and Circles Not Closing Correctly
Hi everyone,
I’m looking for advice with an ongoing motion problem on my CO₂ laser, and ideally recommendations for an experienced laser engineer in or near West Sussex, UK if I cannot solve the issue !.
The machine is an upgraded HPC LaserScript 1290 fitted with:
  • Ruida RDC6555G controller
  • 80W RECI CO₂ laser tube
The main symptoms are:
  • Circles do not join cleanly at the start and finish point
  • Straight cuts have a repeating wavy or jagged appearance
  • Some corners have small tails or distortions
  • The problem appears more noticeable at higher cutting or travel speeds
So far, I have:
  • Cleaned and inspected the X- and Y-axis belts
  • Adjusted and compared belt tension
  • Checked the timing pulleys and drive belts
  • Inspected the rollers, guide bearings and linear motion
  • Checked the gantry alignment
  • Checked the motor couplings and drive shaft
  • Tested the stepper drivers
  • Reduced speed and acceleration settings
  • Confirmed that the artwork itself is correct
I initially found that the Y-axis drive belt was excessively tight. Loosening it removed the abnormal noise, but the poor cuts and distorted circles remain.
At this point, I’m unsure whether the fault is a damaged belt, pulley, bearing, stepper motor, drive shaft issue, electrical problem or something else I have overlooked.
I have customer orders outstanding, so any diagnostic advice would be greatly appreciated. I can also provide close-up photographs, videos of the machine moving and test-cut files.
Thanks in advance.
Hi Paul,
Look like you already take care of all the mechanical. Good point.
Now the next thing I would look at would be any reasons for the stepper motor to skip Step(s).
Is it very hot in your workshop ? Try force cooling the stepper’s drivers, or simply open the side door of the unit.
Hi Stephane,
Thanks for your reply !
The workshop sits normally around 20 - 30 degrees depending on what machines I have running, however this morning its currently 20 and the problem is still there.
I have tried taking the side door off and using a large 18" fan to blow across the steppers, psu’s etc as I was concerned a little about this during the last heatwave !
I’d think, somewhere, you have a loose Y axes. At least something is loose. I base that on your photos. These are sometimes misleading. As it looks good along the Y axes, meaning the X axes is working. It fails along the Y axes.
Both of these show the same symptoms. If you notice where the Y axes should not move, it is.
Also what makes me think it’s something loose, this is next to impossible to make a mistake that can cause this. Sometimes before I get too far, I think can I get the software to do this. I doubt you can without a lot of work, so I’d go with hardware.
Since it’s clearly something loose on the Y axes, I’d start there.
Keeping belts tight, but not too tight is something that is learned from experience. I can’t tell you how to do it, maybe make suggestions.
This can be anything from the head/lens assembly being loose somewhere or about anything else in the gantry system.
Make sense? :thinking:
Any questions, sing out.
Good luck.
:grinning_cat:
Thank you for your input — you were absolutely right that something was loose.
I completely stripped and rebuilt the Y-axis, checking everything from the stepper motor onwards. Although the axis was running smoothly afterwards, it still did not resolve the problem.
I then turned my attention to the X-axis and laser head assembly. I found that one of the laser mirrors had become loose in its holder. It appeared secure at first, but when I physically pressed it, I could feel the movement.
Once the mirror was tightened properly, the problem was completely resolved.
A very simple fault in the end, but one that took me around 36 hours, a partial machine rebuild and a considerable amount of swearing to find!
Thanks again for pointing me in the right direction.
No perspiration. Glad I could help.
Take care and have fun.
:grinning_cat:
