How would you fillet the edge of a model with a CNC?
How would you fillet the edge of a model with a CNC? Do you have to use a round over bit, or a ball nose bit?
I’d use a ball nose, depending on what you want. There are also milling drills, that have a 30 or 45 degree angle, that do well for chamfering sharp edges.
Ok. Thanks for the tip. I’ll give it a shot.
