How well do the default settings work in Simplify 3d for the FF Creator Pro? Just got my machine and ran the test files and want to run one of my pieces from simplify 3d.
It’s just that someone’s made a profile that works for that machine and that’s what loads in if you select it. Sets up a lot of behavior and settings as a starting point so you don’t have to figure all that out.
I can understand that. I guess my question is about the tool numbers (T0,T1) and whether or not it will translate correctly in the Gcode. I have used many CAM softwares in as a pattern maker and machinist. In these the tooling is different with some of the code. Like heating the bed…
There’s a few relatively standardized sets of g code behaviors for 3D printing. The printer selection picks the appropriate settings.
To more directly and clearly answer the original question, I’ve heard the FFCP settings in Simplify are pretty good.
Nail on the head my friend… What I was looking for… In some of the softwares I have used, it was crucial to label all tools exactly… Thank you
