How to get holes drilling?
How to get holes drilling? The gcode for milling and dimension cutting seems just fine but no path for drilling appears, the holes appear on the Drills layer in Eagle, thanks
As mentioned in another thread this is fixd in the tinyg workspace
I’m using cambam to create the drilling jobs and modified the post processor to enable the tinyg to understand the drill commands as it says that some canned cycle commands are not supported by tinyg
changed the output post processor for canned cycles in cambam to accommodate.
Hi I am using gbrl and from the tinyg workspace I can get proper gcode commands
