How to convert a fridge into a connected vacuum pump
I wanted a vacuum pump to laminate RC planes wings using the “vacuum bagging” technics.
This project is how to reuse a fridge compressor to build the vacuum pump.
The full project is open source and open hardware. You can find it on my hackaday’s pages here :
I finally tested this pump on a real foam cut stabilizer.
And it worked very well.
And final result is satisfying although not perfect:
