A friend and I were setting up a cooling bucket(5 gal) and he mentioned needing to keep the tubes coming from the laser away from things which are sensitive to heat because the water leaving the laser tube was really hot. I disagreed claiming if it was the case the little 5g of water would heat up quite quickly but he persisted with the claim.
Does anyone know what the temperature differential is between inlet and outlet when the inlet is ~20C?
