How do people remove the filament from the hotend at the end of a
How do people remove the filament from the hotend at the end of a print or to change over? Just a fast retract while hot?
I had some issues with filament deposits in the heatbreak. Retract during print is set to 6mm for PETG, do I suspect it’s from changing filament.
I drop temp to 110, then cold pull by hand by removing the Bowden tube from the hot end. Cold pulls tend to bring get the majority of the old filament out. If I am changing material types I tend to do a nylon cold pull in between the old and new filament. Nylon cold pulls are great for cleaning out the hotend. For loading and unloading filament I made custom buttons with the the CustomControl plugin in octoprint (one for load, one for unload). With the Bondtech Extruder I could probably use it for cold pulls, but I would need to disable the cold extrude safety check.
Unload:
G91
G1 E-950 F1500
G90
Load:
G91
G1 E950 F1500
G90
How is that for wear and tear on the bowden and couplings?
Mine is fine after more than 1 year, if that is an indicator.
@Eclsnowman Good enough for me :wink:
