How do I slow down the speed of the Check Size movement?
Everything else is fine, except that, it throws out my Y axis when being checked. It seems there is too much acceleration on it
@Tim_Lennard ​ I believe it’s related to the jog fields on the control section.
Can or have you tried reducing it?
I have, I will try again with lower values. It didnt seem to make a difference before.
Jog value can reduce the speed of the movement. In x and y direction
No it doesnt effect it.
