How can I use a led strip (LPD8806) plus an SD card on the same SPI bus on an arduino UNO? the LPD8806 does not have a chip select. can i connect the sd card to software spi pins to avoid bus conflicts?
Keep the SD on the SPI bus, put the strip elsewhere.
